Rear Disc brakes
If you look at a cobalt SS rear axle beam, it has the caliper mount welded to the assembly. A mount would have to be fabricated for our standard rear axle. I started researching this awhile ago, kinda gave up for the time being. The calipers & rotors are the same as the pontiac g6 & other epsilon platforms. Not sure if our hub/bearing assy. is the same as cobalt disc assy, would assume that it is. I would prefer a vented rotor, I may go a different route when I'm ready to do the disc conversion.
jeffs396
jeffs396
jeffs396
jeffs396
On mine.. the brackets were fabricated, and bolted on the back side of the spindle. This was the kit I obtained a year ago... for my Sandstone HHR
